Just bought a 1958 jeep CJ5 with a Poly 318
Ifster
City: White Rock
State: NM
Re: Just bought a 1958 jeep CJ5 with a Poly 318
Post by Ifster »
712edf wrote:
Fri Jun 23, 2023 9:56 pm
Can you tell what color the block is?
Well, maybe not so much. You could almost pick your favorite. But maybe originally red???
Also, there's a huge stumble when the throttle is pressed. I thing I need an accelerator pump. I don't want rebuild the carb, it runs great....on jack stands, in the driveway.
Any suggestion on where i can get the pump for this carb. believe it's a Carter, rebuilt by Holley at some point, according to the sticker on it.
You're doing good with the uploading of pictures. But I can't tell from that shot what T-case it might be. Appears to be missing most of the parking brake components.
I would say red too. That puts it 61-later.
Mopar used Silver, Gold, Turquoise in other years & applications.
Ifster
City: White Rock
State: NM
Post by Ifster »
712edf wrote:
Fri Jun 23, 2023 10:10 pm
I'll dig into it a lot more in the weeks to come, and some better shots.
Thanks
For the accelerator pump & all carb parts.
https://www.carburetor-parts.com/
Those engines mostly came with Carter BBD ( Ball-ball dual) but I have seen Strombergs. I will look more closely at the pictures in the upcoming days.
BigBlockTrucks
City: Binghamton
State: NY
Post by BigBlockTrucks »
712edf wrote:
Fri Jun 23, 2023 9:59 pm
BigBlockTrucks wrote:
Fri Jun 23, 2023 12:47 pm
Didn’t the earlier poly have a third bolt near the middle of the valve cover also?
yes some did.
Mostly because curiosity killed the cat. What year did they go to two bolt covers?
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Ifster
City: White Rock
State: NM
Post by Ifster »
I'd like to replace the thermostat. What make, model truck is going to have this engine, so I can find parts.
The rake on this Jeep cracks me up. That's with extended shackles in the front to try and level it out. Guess this Poly is a bit heavier than the stock engine.
Thanks again.
I have seen 59-later with 2 bolt valve covers. But keep in mind there were dozens of different displacement V8 engines used by Chrysler Corp in the 1950s, some Hemi, some poly, some wedge. I'm not always certain of exactly what engine is in any given picture.
For ordering a thermostat or other parts I would try to use 1962 D100 as the basis.
Ifster
City: White Rock
State: NM
Post by Ifster »
I'll give '62 D100 a shot.
Here are some pics of the trany. Any thoughts on what it might be? The shifter cover is steel.
Thanks again.
That tranny and the transfer case shifter are not factory sweptline issue.
Ifster
City: White Rock
State: NM
Post by Ifster »
What could the trany T-case combo be? Since it's mated to the 318.
Ifster
City: White Rock
State: NM
Post by Ifster »
Seems like the next step for me is to get some casting numbers off the tranny and T-case.
I'm not familiar with the Dodge issue parts prior to 61 so I can't rule that out.
But, that bell is not sweptline era either!
Wildergarten
City: Los Gatos
Post by Wildergarten »
Ifster wrote:
Sun Jun 25, 2023 9:19 pm
Check with a magnet to see if the bell is aluminum. Does the clutch have a mechanical linkage?
Wildergarten wrote:
Mon Jun 26, 2023 8:06 am
It appears to be mechanical & approached from the REAR. As PwrWgnDrvr stated the bell doesn't resemble anything from a 61-68 TRUCK.
Now I am wondering if the engine & bellhousing are from an early 60's CAR & mated to an oddball 3 speed truck transmission. Unlikely that someone could cobble that together though.
Or as he mentioned, pre 1961 Truck.
Looks too archaic to be 69 & later.
nutz
City: phillipburg
Post by nutz »
it might a jeep trans....
ill look under my fc and see if looks like that
Wildergarten
City: Los Gatos
712edf wrote:
Mon Jun 26, 2023 3:49 pm
I had an aluminum bell on an LA318 that resembled your photo. If I recall correctly, it came off a 70s vintage Challenger.
That's why I mentioned the magnet test.
If you do take off the trans, do check the runout on that bell. They can warp. I torqued one to the point that it needed the offset dowels to recenter the A833 trans I had. But gad that Dart wagon sleeper was fun!
Ifster
City: White Rock
State: NM
Post by Ifster »
I've been out for a few days. Just before I left, a buddy stopped 'cause he saw the Jeep in the driveway. He took one look at the tranny and said, that's a T-90. Told me where to look and sure enough it is. He also said the T-case is a Dana 18, but I haven't confirmed that with casting numbers. It likely is.
Bell housing is steel. My friend also did not know what the bell housing was. It is mated to the engine without an adopter.
The flywheel cover is missing, and I was hoping to replace that. So ID'ing the bell housing would still be helpful.
Thanks.
nutz wrote:
Mon Jun 26, 2023 7:52 pm
We have a winner!!
Now to figure out what bell mounts it to the Poly318
