1970 w-100. 5 on 5.5 15's.
The tire shop will not mount 32x10.5 tires or even 30 x9.5 tires. What tires are people running?
tires
- City: Binghamton
- State: NY
Re: tires
Im running 33/12.50 on 16.5x10 rims. Ideally your tread width should be same width as your rim width.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Re: tires
31 x 10.5 x 16.5 on aftermarket wider steel spoke rims.
Re: tires
I'm running their 7.50 x 16 on my W200 but there are 15" available from STA.....
https://www.stausaonline.com/tires/sta-super-traxion/
Made in the USA. Basically what would have come stock
on the Ws back in the day......
Re: tires
Jim,
They're fine with me. Mine are on a W200 with the split ring wheels so
I'm running tubes as well. They hum on the road.... but I like them for
their original look. Hope this helps.
