Here is what Doug had to say about the matter;
My question is, is there any difference between any of the filter housings from year to year on our trucks? Also, if any of you know, do 318's in other vehicles use the same filter housings? I would like to check them too."Here is the problem with the 2020 air filter,as I observe it. It is too short to seat fully at the top and bottom flat surfaces of the filter houseing.What compounds the problem is that it has the same inside diameter as the raised portion of the filter housing lid and bottom. This makes it APPEAR to fit because the inside of the filter is makeing contact with these raised portions of the air filter houseing.
Over time the filter settles into the bottom of the houseing and leaks around the top.Before it settles it leaks around the inside diameter of the filter ,as this area of the filter was not designed with a smooth seating surface ."
Thanks for the help.
