You guys are going to laugh at his..
So I went to pull my wheels the first time on my D200 to check the brakes since I had a pedel/floor experience. No brake fluid in the master. Now I have to bleed the, might as well go through everything...
This is not my first Mopar so I am aware of the Left-hand/Right-hand thead thing, but I got fooled on this truck...
I have reverse (Left-hand) thread studs on all four corners. Somebody didn't order the right parts somewhere along the line on this truck. Flashbacks to my first Mopar trying to get the lugnuts off.
Also does anybody know where to get the special tool called out on the manual to use on the rear Dana 60 to get the drums off?
Brake-Wheel laughs
Brake-Wheel laughs
Harold Davidson
Cesspool of knowledge. All kinds of useless $$hit floating around.
1970 D200
Re: Brake-Wheel laughs
That's funny! Guess u didn't see that damn little L stamped in the ends of the studs on the RIGHT side
Are you trying to remove drums from the hubs or just get them off of the axle? IIRC, on a Dana 60 you have to pull the axle shafts, bearings and then the hub/drum comes off as an assembly. Been too long since I worked on anything that small to remember for sure....
I have never used any special tool to remove the front or rear drums/hubs on my 66 W100 or my old 71 W200 or 76 W200 or any D 200/100
Remove axle nuts and pull axle or spindle nut as needed.. May need to smack axle center with a small sledge hammer to dislodge coned washers and the special tools i use for removing assembly is a very large flat screw driver and a small chisel. Channel lock pliers work well for D spindle nut.
Need to bend back lock tang or remove cotter pin.. You can buy a socket if you want.
So I did some digging and the tool called out in the manual is a 2 3/8 hex socket. They are available from the tool trucks, but I found one on EBay for around $20.
My new issue is do the front drums have a hub pressed into the drum or is it one whole piece. What I have doesn't match what RockAuto or NAPA show. I don't want to get all "Hulk Smash" on it to try and take apart something that doesn't come apart. The service manual isn't all that helpful in it's description, and there's enough rust and dirt to prevent 100% confidence.
here's what I have vs what Rockauto shows
Harold Davidson
1970 D200
After you cut the swage off the lugs and drive them out, the hub and drum come apart.
Actually, looks like you have the later front axle design and the drum just pulls off the hub/lugs.
Either way, the hubs and drums are separate pieces on all swepts.
The drum doesn't just come off the hub, hence my concern about breaking something that is one piece. Since I'm pulling all the studs to replace them with right hand thread anyway, maybe the hub will come off easier with them removed.PwrWgnDrvr wrote: ↑Sun Oct 23, 2022 8:30 pmAfter you cut the swage off the lugs and drive them out, the hub and drum come apart.
Thanks for the info
Harold Davidson
1970 D200
reason to keep left hand threads? to prevent theft! I always leave mine. now reason to switch.
- martincom
- City: Five Points
A press is a much better method to remove/install wheel studs. Quite often, the studs are what keep the drum mated to the hub.
You'll find a press is a necessary shop tool, as many service procedures require it and attempting to substitute a hammer only destroys things. Quite often you can find a used press on Craig's List or Facebook Marketplace, typically $200 or less. I've hears reports of acceptable performance from Harbor Freight units, also.
