Hello
I just installed a new gas tank on my 66 Dodge A100 Pickup . The fuel inlet point on the tank in very low. How does the tank get full with inlet port is towards the bottom ??
Thanks
Fuel tank
Re: Fuel tank
The hose for the filler would be up higher than the tank inlet.
Re: Fuel tank
That would only work if there is an air bleed at the high point of the tank. Same reason you can't mount a slave cyl upside down.
Re: Fuel tank
It just seems like that because the gas level is higher than the inlet you would pushing the gas uphill.
- City: Webster
- State: NY
Re: Fuel tank
wondered if the mustang fuel tank sending unit would work on a Swepty
- moparbay
- City: Rapid City
- State: SD
Re: Fuel tank
Its not perfect but close. Somebody has posted the Fuel Sending units OHMs somewhere on the site, i am too lazy too look for it. i think the ford is
90 ohms empty, 7 ohms full range where the dodge is 73 ohms empty, 10 ohms full range. I am sure someone will correct if i am wrong
moparbay
Ole "Blue" 68 D100 Adventurer
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
