getting the tranny out of a '69
- City: Santa Barbara
Im thinkiong of replacing the clutch. my preliminary scouting has me going hmmmmm. the rear trans mount fits in a three sided socket in front of the crossmember.... It LOOKS like part of it is spot welded, and the side of this box are bolted to the crossmember. You cant pullthe transmission straight back..... and lowering the engine enough to clear is really gonna twist the front m mounts. It LOOKS like the bolted side members are spot welded to the frame..... or do those unbolt? Then i could just rotate the tranny to clear it.... whats the drill on this..... AND, without taking it apart, how can i tell if its a 10.5 or 11 in, or will either size mate to the flywheel holes? Thx.
Re: getting the tranny out of a '69
Ah nevermind... A100.. I'm of no help here...
My truck is a swapped in automatic, and I'm pretty sure that the engine and trans were guided in from the front as a unit. Like you, I have easily removed the rear-most tail shaft cross-mount but the original cross-brace runs directly under my trans pan. That prevents me from dropping it down.
I know the prior-prior owner/builder had planned on swapping out the permanent brace for an original removable cross-brace as he included one painted up with the truck as if that was his plan. However before I did that, I need to re-route my brake lines and I'd like to weld in a cross-brace driveshaft loop to everything together.
Thank you Terry!
Thank you Terry!
There shouldn't be a x-member, the tranny is mounted by at the top middle of the tranny. Someone did some #@&%$# jerry rigging from what your saying. Sounds like you got your hands full, It should look like this! Good Luck
https://board.moparts.org/ubbthreads/ub ... stail1.jpg
https://board.moparts.org/ubbthreads/ub ... stail2.jpg
https://board.moparts.org/ubbthreads/ub ... 9a-108.jpg
My 69 had one with a center rubber mount under the tailshaft housing of the NP435. If I recall correctly, the brackets were riveted on the frame and the crossmember bolted to the brackets (unlike my '68 which has rear mounts on the bell housing), but the arrangement was definitely OEM. I'll take a look later today.
Mark, its an A100 van, not a truck.....they're weirder.Wildergarten wrote: ↑Tue May 05, 2020 8:03 amMy 69 had one with a center rubber mount under the tailshaft housing of the NP435. If I recall correctly, the brackets were riveted on the frame and the crossmember bolted to the brackets (unlike my '68 which has rear mounts on the bell housing), but the arrangement was definitely OEM. I'll take a look later today.
Oh.PwrWgnDrvr wrote: ↑Wed May 06, 2020 12:34 amMark, its an A100 van, not a truck.....they're weirder.Wildergarten wrote: ↑Tue May 05, 2020 8:03 amMy 69 had one with a center rubber mount under the tailshaft housing of the NP435. If I recall correctly, the brackets were riveted on the frame and the crossmember bolted to the brackets (unlike my '68 which has rear mounts on the bell housing), but the arrangement was definitely OEM. I'll take a look later today.
"wierder", indeed, which is why i like joining this group. What ive learned from others: its DESIGNED to be lowered staight down as a unit- the engine & trans- BUT the front mounts, if not dried out- mine are new- will allow the thing to tilt enough it will clear the pocket its in....ive lowered the rear on other clutch jobs ive done, but this requires a much greater drop. As ill be doing this all by myself.... well, ive done a lot of major work by myself, so....i got a hd clutch lined up at Summit. Now i gotta locate the trans mount biscuit, as this one has "setteled" quite a bit over the past 50 years.....
