Any ideas, it's a 318, Alternator module???
thanks guys!
ps I was looking at wiring diagram, what is an ''ammeter'' and where is it on a stock 1967 318 A100 van???
what is this?...(pics)
- RH62
Re: what is this?...(pics)
voltage regulator.
can i temporarily bypass and connect those two wires? would a problem inside, keep the van from starting? and if i need it, do i just ask for a ''universal'' voltage regulator at autozone? (its not factory stock i assume)
thanks again
thanks again
- RH62
Why would you?
- RH62
If you bypass it you'll prolly blow the light bulbs out and may damage something. They are cheap just go to kraigen and get a new one.
Hey thanks
- SwampRat
- City: Biloxi
- State: MS
tried to bypass that voltage regulator before, don't do it or have a fire extinguisher readymercado wrote:can i temporarily bypass and connect those two wires?
