WANTED A100 318 transmission
- City: Plymouth,Wi
I'm in Wisconsin and in need of a transmission for an A100 They have the mountson top.If anyone in Wisconsin or the surrounding states has one either good or a core ,give me a shout.I'd appreciate it.
dougnal@yahoo.com
dougnal@yahoo.com
- Dodgevanman
- City: Baltimore, MD
Re: WANTED A100 318 transmission
Some of the 70's Dodge pickups w/divorced transfer case used the same transmission. Some Dodge motorhomes also used this type of setup.
Nate the skate
'94 B250 Conversion Van
'72 B200 Sportsman Maxiwagon
'67 A100 Van
'67 A100 Van
- 440SCOUT
- City: reno nv
- State: NV
All the trucks and motorhomes i have seen have the regular trans mount whereas the a100 has the bushing mount pressed into the casting of the tailhousing... maybe the transmissions are the same and you could just swap the tailhousing...??? MAYBE...Dodgevanman wrote:Some of the 70's Dodge pickups w/divorced transfer case used the same transmission. Some Dodge motorhomes also used this type of setup.
- City: VFDVFG
- State: AZ
Kingmankid wrote:I'm in Wisconsin and in need of a transmission for an A100 They have the mountson top.If anyone in Wisconsin or the surrounding states has one either good or a core ,give me a shout.I'd appreciate it.
dougnal@yahoo.com
Hi , I am a new member of forum. Would a newcomer be warmly welcome here? Good day you guys!!!
Yes, although the A100 section doesn't get a lot of use because most of the regulars are Sweptline owners.jezzicaz789 wrote:Kingmankid wrote:I'm in Wisconsin and in need of a transmission for an A100 They have the mountson top.If anyone in Wisconsin or the surrounding states has one either good or a core ,give me a shout.I'd appreciate it.
dougnal@yahoo.com
- City: Atlanta
- State: GA
Do you still need a transmission for an A100? I will have one available soon.
The original poster hasn't visited the site since August of 2008, unless they weren't logged in.rhabneyA100 wrote:Do you still need a transmission for an A100? I will have one available soon.
Simple question. Could someone post a picture of an A100 small block trans in a van for me so I can see it. I have a 68 318 trans that has been in storage since 1977 but one of the mounts got broken. Just not sure if the broken mount will be a problem. It will be for sale at some point in the future when I know if its OK as a good core.
- City: Atlanta
- State: GA
What is the number of the Automatic trans for an A100? Is it called a 318?
What is the number of a "short tail" Duster auto trans need to fit an A100?
It is a 727. Here is a picture.rhabneyA100 wrote:What is the number of the Automatic trans for an A100? Is it called a 318?
![Image](http://i.ushipcdn.com/resize.php?path=%2Fstatic%2F1efc4607-8271-4f41-b.jpg)
That's the trans that I have in the picture. One of the mounts on the top of tail shaft on my trans is snapped off.
Tail housing can be replaced from another trans . Been sitting in dry storage for 36 years.
Is tranny still available?rhabneyA100 wrote:Do you still need a transmission for an A100? I will have one available soon.
- City: knoxville
I realize this is an old post, but I have a 318 A-100 727 trans for sale. hit me upKingmankid wrote:I'm in Wisconsin and in need of a transmission for an A100 They have the mountson top.If anyone in Wisconsin or the surrounding states has one either good or a core ,give me a shout.I'd appreciate it.
dougnal@yahoo.com
