Capable Slant 6?
- Brudog
- City: Richardsville
- State: VA
Capable Slant 6?
Hello all.
I have not found much info on towing capacities, etc. With a Slant 6 in my W200 Crew Cab, is there any hope of ever pulling a camper, or a tractor / car on a trailer?
If my pipedream is to use the truck for these truck-like activities, what would you recommend?
- Brudog
- State: VA
Re: Capable Slant 6?
How much does it depend on the capacity of the rear axle? (Rear Axle is a 4.10 Ratio Dana / Spicer 60; Capacity = 5500 from the tag)
I apologize for the "dumb" questions, as I am not the most knowledgeable when it comes to these things. Haven't really pulled anything with a truck before. My Silverado was used for loads of dirt, mulch and sand only.
There is hope.... but with 127hp at your disposal and a 4.10 gear, you'll probably haveBrudog wrote:Hello all.
a slow journey. I'm sure some here can help you out with GVW / GCVW information.
- Brudog
- State: VA
If upgrading is the recommended suggestion, I would like to hear folks' opinions on what power plant I should upgrade to. We will start by ruling out a diesel conversion at this point, as I know nothing about diesel engines and the conversion would probably be light years beyond my expertise level.
Are there any sufficiently-sized engines that would mount up directly to my New Process 435 transmission? Or no matter what, I will need to change transmissions as well? (And I probably know less about transmissions than I do diesel engines ) It will all be a learning experience...
Any advice is greatly appreciated.
Jim,Brudog wrote:If upgrading is the recommended suggestion, I would like to hear folks' opinions on what power plant I should upgrade to. We will start by ruling out a diesel conversion at this point, as I know nothing about diesel engines and the conversion would probably be light years beyond my expertise level.
An A318 or LA318 would bolt right up to your current bell housing.
You would need the correct flywheel and probably a better radiator
to cool a V8 down. That would be the easiest option and it would
get you sufficient power/torque to do what you need to do.
สมัคร sbobet
สมัคร sbobet
sure the slant can tow... just may only do 45mph doing it..:)
As Mentioned above look for a good LA 318. I had a slant six and went with a 318 and it was a pretty noticeable increase in performance and it was a bone stock mild LA 318.
jim
jim
Where is your question?Macros wrote:I apologize for the "dumb" questions, as I am not the most knowledgeable when it comes to these things. Haven't really pulled anything with a truck before. My Silverado was used for loads of dirt, mulch and sand only.
สมัคร sbobet
John, Macros quoted the OP.....Hobcobble wrote:Where is your question?Macros wrote:I apologize for the "dumb" questions, as I am not the most knowledgeable when it comes to these things. Haven't really pulled anything with a truck before. My Silverado was used for loads of dirt, mulch and sand only.
สมัคร sbobet
Macros is a spammer.Hobcobble wrote:Where is your question?Macros wrote:I apologize for the "dumb" questions, as I am not the most knowledgeable when it comes to these things. Haven't really pulled anything with a truck before. My Silverado was used for loads of dirt, mulch and sand only.
สมัคร sbobet
Thanks for the heads up you two.
- riffraff
- City: Newport Beach
As far as official Dodge specs, the below links to the 1969 Dodge Truck brochures I scanned should answer your questions. Not sure how well the specs work out in the real world, but I think Dodge put out honest info:Brudog wrote:Hello all.
viewtopic.php?f=33&t=37948
Let me know it the links are dead, as I know Dropbox recently made some changes that may have impacted the links.
Tom
1969 W100 383/435
1969 W100 383/435
