Dodge 2 ton truck
- City: Borger
Re: Dodge 2 ton truck
This is the 71 donor truck to my blue 70. Kind've a shame to tear it apart but I'm partial to my 70 and don't need 2 dump trucks.
- City: Borger
- City: Borger
Got all the body prices I need swapped. It's not right but good enough.
- City: Borger
- City: Borger
Here's how to take the door glass out with pictures, there's a little inspection plate you take off and inside there is the smokers window bottom support. Take the bolt out of there
- City: Borger
- City: Borger
Then there will be another bolt access hole by the top hinge, take that bolt out
- City: Borger
- City: Borger
Then about a inch and a half or so there is a screw that has to be taken out under the weather stripping
- City: Borger
- City: Borger
On the latch side of the door will be two more access holes for bolts that have to come out, the picture about is the first one
- City: Borger
- City: Borger
The picture above is the second bolt hole. It's the larger out of the two. Then the top of the door should be able to be worked out.
