I've got a '66 D200, I often have to "double pull" the driver's side door handle to get it to open: to open the door, I have to pull the handle, let the handle snap back, then pull it a second time. I have a similar problem trying to open the door from the inside; I sometimes need to 'jiggle the handle' and gently lift on the door to get it to open.
Is there an adjustment or recondition I can do to some of the latching mechanisms? Any suggestions as to what might be going on?
Also, am I correct in thinking that when I pull on the outside door handle, the star wheel should rotate? Or does pulling the handle simply release a 'lock' mechanism that lets the star wheel rotate (and disengage from the striker)?
I've been reviewing a lot of posts about door latching. Based on this post (viewtopic.php?f=5&t=32075&p=241456&hili ... ch#p241456) it looks like you can remove the door latch assembly from the door fairly simply; remove four screws and work it out through the openings on the inner door (after removing the cosmetic panel). Does that sound correct? Once I've got the latch assembly out, am I correct in thinking I'm in a good place to use one of the freshen-up techniques outlined here? viewtopic.php?p=283063#p283063
Thanks for any suggestions.
door latch works inconsistently - '66 D200
Re: door latch works inconsistently - '66 D200
Star wheels, strikers and hinge pins wear out and cause binding. Fix those and you're well on the way to smooth operating latches
- hmaynord
- City: fairhope
I can't answer your ?s, but those guys with 1,000s of posts in this thread that you reference always -- almost always ?? -- give good advice:
patrino wrote: ↑Sun May 03, 2020 1:18 pm...
... Once I've got the latch assembly out, am I correct in thinking I'm in a good place to use one of the freshen-up techniques outlined here? viewtopic.php?p=283063#p283063
harris
driving it since 12/03/71
