hey guys im in need of some help. Its not for my swepty but for my 74 power wagon. Ive had the truck about four months and ive fixed things here and there. well in the last two weeks ive had problems beyond problems. the first was a short in my tail lights that fried my turn signal switch. The second was my speedo cable was shot, i just now got a new one in today. now my speedo is acting up so i was just workin on cleanin that up. Now the real problem is i just test drove the truck to see how the speedo was behaving. I got down the road and then my fuel and temp gauge were all the way up, so i hurried and got home and shut it down, well now my gauges arnt doin anything im gettin way to much power everything it seems, lights signals, fan blower, ect. there is a plug that plugs in to the back of the gauge package that runs every thing it only goes in one way, also it has the two wires for the amp gauge, i made sure those were right. I thought maybe the voltage reg not to sure though i had an extra from a parts truck, but it didnt even get power to nothin at all as far as i could tell so im not sure if its even good. On top of that my speedo still dont work right. If anybody has any ideas i would greatly appreciate it very much so. im gettin to my wits end.
Thanks Sherman
Help!!!
- 64200pshbtn
- City: las cruces
- State: NM
Help!!!
Sherman
64 D200 pushbutton auto trans
66 d100
48 & 49 B1PW power wagon
66 d100 413
62 d100 utiline /6
66 d100
66 d100 413
62 d100 utiline /6
- 64200pshbtn
- City: las cruces
- State: NM
Re: Help!!!
Just did some testing on some voltage. The least voltage i was getting was roughly 18 to 19v im gettin way over kill in some areas as high as 42v. Another question can gauges such as temp and fuel fry because of too much voltage...
Sherman
66 d100
66 d100 413
62 d100 utiline /6
66 d100
66 d100 413
62 d100 utiline /6
- chilort
- City: Cookeville
Re: Help!!!
Yes.64200pshbtn wrote:Just did some testing on some voltage. The least voltage i was getting was roughly 18 to 19v im gettin way over kill in some areas as high as 42v. Another question can gauges such as temp and fuel fry because of too much voltage...
- 64200pshbtn
- City: las cruces
- State: NM
Re: Help!!!
thanks, um i replaced the alt and vlt regulator. Im still getting a little on the high side for volts around 18. no more numbers around 42v to 52. now i was wondering if any one has a wiring diagram for 72 to 76 dodge trucks, this is the one i really need and i would greatly appreciate, if some one could email or post it here. i need to go through the whole wiring system and check everything. The bad thing is i really hate wiring on vehicles. so any help i would be very grateful for. oh and ill post this in the electrical section too.
Thanks again Sherman
Sherman
66 d100
66 d100 413
62 d100 utiline /6
66 d100
66 d100 413
62 d100 utiline /6
- tinbasher
- City: Cache Creek
Re: Help!!!
might want to check and see that your battery has a good ground to the body... same with your engine.
some guys just drill a small hole right in the speedo mechanism and load it up with wd40... i would think 3in1 oil would be better.
Bob
63 D300 313 4sp
93 W250 Cummins/auto
74 W200 Power Wagon 360 4sp
88 B350 360 auto
76 American Clipper 440-3 auto
99 Plymouth Voyager 3.0 4sp auto
63 D300 313 4sp
88 B350 360 auto
- 64200pshbtn
- City: las cruces
- State: NM
Re: Help!!!
ok cool thanks ill check it out, its seemed so good so far for grounds, but ill double check. I think ill just end up goin through the whole wiring system
Sherman
66 d100
66 d100 413
62 d100 utiline /6
66 d100
66 d100 413
62 d100 utiline /6
- 64200pshbtn
- City: las cruces
- State: NM
Re: Help!!!
thanks to all who helped out and gave info i really appreciate it. I seem to have gotten it fixed, i just to find a temp and fuel gauge.
Thanks again
Sherman
Thanks again
Sherman
Sherman
66 d100
66 d100 413
62 d100 utiline /6
66 d100
66 d100 413
62 d100 utiline /6
