Passenger Door Key lock
Fargone
City: Ontario, Canada
Post by Fargone »
I have a '65 Utikine.
On the passeger side there is no connector from the key lock to the locking mechanism and nothing fallen to the bottom of the door.
Was a passenger locking door an additional option on these trucks?
1965 Dodge D100 Utiline
1951 Dodge DG1 (B3B)
1942 Fargo FL1 (WC)
1941 Chrysler C28 Windsor Club Coupe
1938 Dodge D10 Sedan
Re: Passenger Door Key lock
65 lock doesn't have a connector rod. Link shows 61 to 66 door locks. Is your door lock similar to one's in picture. Does your truck have a door lock hole below handle. :thinking :thinking
51 to 65 door locks.jpg (12.55 KiB) Viewed 1303 times
Fargone
Post by Fargone »
dodgeboykim wrote:
Thu Sep 15, 2022 12:53 pm
Yes the door lock is below the handle. On the drivers side there is a open square where the pin locks and unlocks via an arm about 2.5 inches long pivoting to engages at the locking mechanism. This arm is missing on the passenger side and is not in the bottom of the door
1942 Fargo FL1 (WC)
BigBlockTrucks
City: Binghamton
State: NY
Post by BigBlockTrucks »
If it’s anything like the trucks in New York there are holes in the door bottom. Maybe it was in the door, or someone was inside that door before you were and lost it.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
