Alternator Exciter Wire on '61
Snowdog
City: Red Deer
Post by Snowdog »
I have a Rebel harness, which I love, and it has a wire marked as alternator exciter.
Is that something compatible with the alternator on my '61? My reading so far has not helped. If the exciter is to be attached, to which terminal on the alternator does it connect?
1961 Dodge D-100
Alberta, Canada
Re: Alternator Exciter Wire on '61
If anything, it would go to the regulator on the firewall. What is marked on the other end of that wire?
Snowdog
City: Red Deer
Post by Snowdog »
Thank you.
The other end just goes to the fuse panel.
1961 Dodge D-100
Alberta, Canada
If it is connected to the regulator the other end would never be connected through a fuse, nor a hot terminal on a fuse panel.
BigBlockTrucks
City: Binghamton
State: NY
Post by BigBlockTrucks »
More clarification is needed to resolve.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Snowdog
City: Red Deer
Post by Snowdog »
Thank you for that article...looks more complex than I'd have hoped. I'll have to have a better look at my wiring kit.
1961 Dodge D-100
Alberta, Canada
soopernaut wrote:
Wed Aug 09, 2023 5:18 am
I take it you've read this: https://toolsweek.com/how-to-wire-excit ... lternator/
WTF???
That guy has no efn clue and that site is full to overflowing with bullscheiss!
Simply follow the wiring diagram in the FSM and forget about what the wires are labeled. Electrons don't give a scheiss what color insulation is on a wire, nor what the wire is called.
