64-65 tail light housing removal
Red383
City: Fort Loramie
State: OH
Post by Red383 »
Anyone know how to remove the round tail light housing on a 64-65 D200? Do I have to drill out these rivets?
Thanks
Re: 64-65 tail light housing removal
Yes, if its riveted.
Yes, if its riveted. Are you sure they're not studs with nuts on the back?
Red383
City: Fort Loramie
State: OH
Post by Red383 »
My first thought was that the rivits are holding some kind of spring clip, but I tried prying out the housing with no luck. I don't see any way to access the back side of the housings to see what is actually back there. I guess I can remove the rivets and rebuild it after I get it all out.
Anyone else have suggestions before I do this?
Thanks
hmaynord
City: fairhope
Post by hmaynord »
way to go txas2step for posting and soopernaut for finding :clap . saves OP lot of unnecessary work.
harris
driving it since 12/03/71
Red383
City: Fort Loramie
State: OH
Post by Red383 »
Thanks soopernaut, I tried the search feature, but didn't find that post. I must have searched for Taillight, instead of Tail Light.
I will give it a yank and see what happens.
Aaron
Red383
City: Fort Loramie
State: OH
Post by Red383 »
I pried and pulled and here is what I found.
There are three clips that hold the housing in. all three broke when I remove the housing. The stud goes top center and keeps the housing from turning.
Red383 wrote:
Thu May 10, 2018 7:41 am
I did that first. I knew there had to be a post about it so I tried other similar searches.
As I vaguely remember, I think I completely removed the clips and used a hole clip on the 3 body holes for the lens. Those secured the light base and lense to the body. :thinking :Thumbsup
https://www.ebay.com/itm/20pcs-5-8mm-Ho ... SwsGdaujoX
Red383
City: Fort Loramie
State: OH
Post by Red383 »
I decided to replace my tail light housings since they were rusty and bent up. I picked up a pair of the Peterson M425s trailer lights.
I had to open up the tail light holes a little, and trim down the new housing a little. I also picked up a new pair of lens' and gaskets.
It will all look stock from the outside.
Red383
City: Fort Loramie
State: OH
Post by Red383 »
Here are the new taillights
And the brake lights
slick
City: Tucson/AZ
Post by slick »
those look really good :Thumbsup
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
BigJimG
City: Flint
State: MI
Post by BigJimG »
I did something similar on my '63 which had International Truck tail lights poorly installed. I ordered 24 LED rear rubber mounted housings, and installed them. I had to trim opening in the same way, but the rubber housing fit fine in the factory stamping.
'63 D100
