starting issue
starting issue
1970 w-100 la small block and electronic ignition.
Battery is good.
I turn key and it makes a clicking sound and that is it. I can get it to start by wiggling back of ignition swith at times or somtimes by turning the lights on and off or blower on and off.
Is this sound like just a bad connection in there or solenoid? Or ignition switch? Maybe the turning of things off and on is coincidence.
Thanks jim
Battery is good.
Thanks jim
Re: starting issue
Don't know about a 70 model but my 66 has a solenoid on the inner fender, driver side. Replaced it years ago when it failed with one for a Ford.
Re: starting issue
You can jump it with a screwdriver to test it
Re: starting issue
When it just clicks with the key if I poke a big screwdriver down on the solenoid and bridge the terminals all it does is make some sparks. Should it not make the starter turn if all was right?
jim
jim
Re: starting issue
Yes, it should turn the starter over. You are jumping the small wire to the BIG wire... right? OH, It won't start if the key is off, but it WILL turn over even if the key is off. I would "GUESS" that if you jump it over and only gives sparks, you either have a battery that will work the lights, but not enough AMPS to turn it over. OR, starter is JAMMED, OR starter is bad, OR cables on starter are just dirty and need to be cleaned. Just a couple things to try out.Jim100 wrote:When it just clicks with the key if I poke a big screwdriver down on the solenoid and bridge the terminals all it does is make some sparks. Should it not make the starter turn if all was right?
jim
Re: starting issue
Is the starter relay likely to fail intermittenly?
Also does it have to be grounded where it is fastened ?
jim
jim
- City: Rio Linda
Re: starting issue
Yes, sometimes the contacts inside "weld" themselves together (or get corroded and/or dirty) and about the grounding, I just screwed it in, but don't think so. Part of my spare parts I carry.Jim100 wrote:Is the starter relay likely to fail intermittenly?
jim
Re: starting issue
Hmmm.... also, make sure that 4th "tang" is grounded. On my '68, I had to ground that tang with a small wire in order to make it work. Not sure if that could be part of your problem. SEE PHOTO of the YELLOW wire going to the "tang" (circled in RED) that I have on my truck that goes directly to a ground. It's worth a quick look.
Re: starting issue
For whatever reason my relay has only one blade. The second blade on the two blade relay is a ground wire you say?
Re: starting issue
I forget... Tomorrow morning, I will take a better picture of it. From what I remember, the earlier Swepties had the 3 position relay whereas the 69+ had a 4 way one. They had an extra wire in the harness for it, but I believe it only went to a ground "somewhere".Jim100 wrote:For whatever reason my relay has only one blade. The second blade on the two blade relay is a ground wire you say?
anyone else chime in about this?? Been a LONG time!
Re: starting issue
See the picture of the 4 connections Starter solenoid. This one was for a later model and that is why it has 4 connections on it. My 68 original one only had 3 connections and grounded through the body of the solenoid. Maybe that wasn't good enough and that is why they changed them? I don't know... but I know I had to make up a small (YELLOW) ground wire to make it work. STILL.... you should be able to BYPASS this whole thing by jumping the "Screw" to the "Bolt" and if your starter turns over each time, then you KNOW it isn't the starter. However, if it still just shoots sparks and doesn't turn the starter over, check your battery, make sure your cables are CLEAN at each point, and also check your starter... Maybe it is jamming and works sporadically?
Re: starting issue
Thanks will check and clean all connections. jim
Re: starting issue
I'm thinking that 4th terminal would be for a vehicle equipped with anJims68 wrote:See the picture of the 4 connections Starter solenoid. This one was for a later model and that is why it has 4 connections on it. My 68 original one only had 3 connections and grounded through the body of the solenoid. Maybe that wasn't good enough and that is why they changed them? I don't know... but I know I had to make up a small (YELLOW) ground wire to make it work.
automatic tranny neutral safety switch....
Re: starting issue
Sounds logical! I'll buy that!Hobcobble wrote:I'm thinking that 4th terminal would be for a vehicle equipped with anJims68 wrote:See the picture of the 4 connections Starter solenoid. This one was for a later model and that is why it has 4 connections on it. My 68 original one only had 3 connections and grounded through the body of the solenoid. Maybe that wasn't good enough and that is why they changed them? I don't know... but I know I had to make up a small (YELLOW) ground wire to make it work.
- City: Rio Linda
Re: starting issue
It is, I thought that was a given, sorry.Hobcobble wrote:I'm thinking that 4th terminal would be for a vehicle equipped with anJims68 wrote:See the picture of the 4 connections Starter solenoid. This one was for a later model and that is why it has 4 connections on it. My 68 original one only had 3 connections and grounded through the body of the solenoid. Maybe that wasn't good enough and that is why they changed them? I don't know... but I know I had to make up a small (YELLOW) ground wire to make it work.
automatic tranny neutral safety switch.... :thinking :Thumbsup
Re: starting issue
Nothing a given with my operation! Ha Ha.
Thanks for the help everyone as I feel it must be a bad starter. Battery good. I cleaned every single connection to bare metal and used a tiny bit of the electrical grease.
Still the clicking so i did the big screwdriver jump of the two posts on the starter motor and just sparks.
I dont know what magic the solonoid performs but -6 cant help. Im going to pick up a new starter.
Thanks guys
Thanks guys
