I’m finally re installing my parking brake lever and cable on my 70 1/2 ton after a full restoration.
For some reason I can’t find the photos I took of the handbrake lever before I disassembled it and restored the parts.
Can anyone help me out with a photo or description showing where this long spring goes? I’m pretty sure the 90 degree end goes to the bolt that holds the lever bracket to the firewall, but I want to install it correctly so that I don’t have to pull it out and correct it if I’m wrong.
Cheers!
Hand brake spring
- City: Cochrane
Re: Hand brake spring
Only place I remember a spring is the return to resting position under truck where cable join for rear axle.
- City: Cochrane
Could you post a photo of the spring in your truck Kim?
- City: Binghamton
- State: NY
I just looked at mine and there is no spring or even a place for one that I can see.fireguyfire wrote: ↑Mon Jan 02, 2023 12:21 pmI’m finally re installing my parking brake lever and cable on my 70 1/2 ton after a full restoration.
Cheers!
I’m glad this topic came up though. Mine was missing the cotter pin that holds the 5/16 pin from falling out on the end of the cable.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
fireguyfire wrote: ↑Mon Jan 02, 2023 4:21 pmCould you post a photo of the spring in your truck Kim?
Cant currently get near truck in garage. Its surrounded with girlfriends crap. I would if I could. Sorry.
- Red383
- City: Fort Loramie
- State: OH
Here is a picture of the spring on my 65 w200.
- City: Cochrane
Thanks!
