1969 D300 Disc Upgrade
1969D300
City: Northeast
Post by 1969D300 »
OK guys, I've been wanting to do this for a long time to my dually but there are no real options out there that I know of that allows me to retain the original front axle. The only way I know to do this and retain a 2 wheel drive front axle, would be to remove mine, swap in a D200 front axle, use the scarebird kit, and run an adapter, something similar to this---> https://www.southwestwheel.com/p-1891-aa-4fp.aspx. The only other option I know of is finding a later model 4 wheel drive front axle from a dually and swapping it in.
I have access to a mid 60s D200 crew cab parts truck and can get anything I want off of it whenever, so I am seriously contemplating this if it makes sense. Would the steering components bolt up if I went this route?
Do any of you have any other suggestions?
1969 D300- 318|NP435|Dana 70 4.88s
Wildergarten
City: Los Gatos
Re: 1969 D300 Disc Upgrade
Post by Wildergarten »
1969D300 wrote:
Wed Aug 03, 2022 12:27 pm
That's no walk in the park either. Switching the hubs to SRW on a Dana 60 is a spendy option, and getting the lugs right very tricky. Check my build thread on that. Then there's the drag link and steering arm. Several people here have done the crossover to reduce bump steer during that process, which gets into frame reinforcement. I chose not to go that route so that I could do a PTO winch but you would have more room on a W300 for that.
Perhaps a 70s full size Dodge motorhome would have something that would fit.
This has me confused. Are you seeking to have front disk brakes on your solid beam D300 dually axle? I am guessing that hubs/rotors from 75-93 D300 trucks won't fit due to them being from IFS?
94-01 3500 series CAB CHASSIS 2wd duallys had a solid beam front axle with 8 lug disc but the bolt pattern may be metric & spring perches would have to be added to the housing.
70's motor homes with solid axles were likely M400 series & would have 5 lug Budd wheels.
Daniel24
City: Munfordville
State: KY
Post by Daniel24 »
The Ram Man Inc makes a D300 front disc brake kit.
Daniel24 wrote:
Tue Aug 16, 2022 3:03 pm
Does it fit a dually axle?
712edf wrote:
Fri Aug 12, 2022 8:59 am
I think it was on Rockford Files that I recently saw a full sized motor home with 8 lug wheels. It may not have been a Dodge.
1969D300
City: Northeast
Post by 1969D300 »
It's not for a dually though. Single rear wheel truck only to my understanding.
1969D300
City: Northeast
Post by 1969D300 »
I would like to put disc brakes on the front of my D300 axle but I do not believe it is possible to do so with current aftermarket parts that are readily available.
I did not know that about the 94-01 dodge trucks having a solid axle. I'll look into that for sure! Thanks for the tip.
1969D300 wrote:
Wed Sep 07, 2022 7:44 am
Yes it is the 3500 series 2wd CAB CHASSIS only, not the trucks with pick-up beds. Those don't have leaf spring suspensions but some sort of 4 link with maybe coils, IDK. But definitely a solid straight tube. It was the same suspension the the 94-01 4x4's had.
reallylongnickname
City: Ottawa, Ontario
Post by reallylongnickname »
Anyone know if the D300 disc conversion kit by the RamMan would work on a W300? He has both 6 and 8 lug pattern. Kit is designed to work with factory setup.
Ain't gonna work on a W300.
reallylongnickname
PwrWgnDrvr wrote:
Wed Mar 22, 2023 9:53 am
Well man, he makes a kit for D100, D200, D300, W100, W200, but not W300. Is there just not the demand? Would think there's enough W300s for one small business to make em. Ray Suiter is not doing it anymore 😕. I believe Helitool is also Ray Suiter.
