D400 Wheel cylinders and hardware
- Grodr625
- City: Seattle
Hi everyone, I am working on tidying up my drum brakes on my S400/D400 bus. The rear brake lines I replaced were 1/4" tube 7/16-24 thread. I can only find rear wheel cylinders with 7/16-20 threads. After much searching on this forum, the conclusion I came to is that "Parts are available except for drums and shoes" and that with some measurements and cross referencing potentially some International parts can be adapted.
Anyway, I am on the hunt for all four cylinders and respective brake hardware. Can anyone point me in the right direction? Napa does not list these via light or medium duty databases. Will the 1/2 ton stuff work? I'm assuming I need 1.5" bore, but worried that the thread size on this isn't compatible and would rather not have to run anymore adapters.
http://www.dormanproducts.com/itemdetai ... ame=w28850
Thanks for any and all input.
1964 S400 318 poly 4 speed - Linda aka Big Booty Judy
Previous swepties:
1968 D100 318, Hardworking Herbert
1966 D100 318 poly 4 speed - Ginger/Sancha/CrucesCruiser
https://stavisaves.wordpress.com/
Previous swepties:
- Grodr625
- City: Seattle
Re: D400 Wheel cylinders and hardware
Hi John, I've checked Rockauto, but was unsure how to correctly source D400 parts since they only list up to a 300 series.
Looks like the D100 cylinders are 1" bore and the D300 cylinders are 1.25" - which matches bore on my MC. Do 300 and 400 series brake parts match?
My confusion is that the dorman part that I linked in my initial post indicates is for a D400 according to application listing and shows 1.5" bore.
Also when checking the D300 cylinders the listings show 7/16-20 threads on all front cylinders except for https://www.rockauto.com/en/moreinfo.ph ... cc=1329421
This shows 7/16-24 for front right, but the corresponding front left shows 7/16-20 threads.
Any further insight? Should I just go for the D300 stuff at 1.25 bore and worry about thread pitch later?
Previous swepties:
Previous swepties:
You might want to try a medium/heavy duty truck parts supplier.
You can also hone your cylinders and install new cups if they aren't pitted, or have them lined with stainless if they are.
your project is pretty cool and unique..
but i think you can only do so much research online.
at some point you just need to have the parts in hand.. at least they are not a big investment ! rockauto has one of the D300 dormans on closeout for $3.
i remember my D100 had many different threadings for flare nuts, perhaps it was a system to avoid mixing up parts front / rear / left / right.
the easiest way out might be to bend your own hard lines with custom fittings.
you're probably going to need lots of hard-to-find things for the project over time.
you could find a helpful friendly knowledgable guy at the local NAPA or similar parts counter who will be your ally.
the guys at my shop are not experts in Dodges or anything, but they are always helpful and willing to look stuff up and show me the picture in the computer so i can double check what I'm getting. they'll look things up in the old paper catalogs too by dimensions (like the time i needed an endless drive belt for my southbend lathe or a fuel filter for my single cylinder norwegian diesel) definitely non standard applications !
they have lots in stock too but can get most other things delivered in one or two days. they usually take returns if stuff turns out incorrect.
at the end of the day, they get a kick out of keeping the old equipment running and like to see it drive by.
the truck specialist shops in the industrial areas are probably a good bet for this job too. my local truck brake shop was very helpful when i needed my drums turned, and they were glad to order parts i could not find elsewhere.
have you tried any of these guys in Seattle ? :
-Brake and Clutch Supply, Inc.
-West Seattle Brake Service
-FleetPride
the option to reline and rebuild your original cylinders is good too, especially if the current ones are made in USA and you'll be keeping the truck for a long while.
only thing is the expense.. the shops around here charge somewhere near $75+ per cylinder
good luck !
-FleetPride
good luck !
- Grodr625
- City: Seattle
You make a good point, but I'm certain that somewhere in Internet land is a parts breakdown with Chrysler part #s for a factory brake setup on a D400. This is what I was hoping for, but will take advice given here and break it apart in hopes of matching casting #s to a good part #.coelcanth wrote:your project is pretty cool and unique..
-FleetPride
good luck !
I have been to Seattle Brake and clutch and will likely have them reline shoe steel, if needed. Will be checking with Fleet Pride as well! Best case scenario- we replace 4 cylinders and hardware and adjust shoes. Fingers crossed
Previous swepties:
Previous swepties:
i can see you have a tough project ahead of you ..
there is almost no mention of the 400 series in the literature !
- Grodr625
- City: Seattle
soopernaut wrote:Did you look through any of this?
http://sweptline.org/brakeservice63_68/index.html
This is excellent! Are you able to cross to part #s based on the numbers given here? Is there an accompanying index, or are these to be understood as Oem Mopar part numbers? I see the rear brake diagram, but not the front, are they identical? Was trying to find a part # on the wheel cylinders, but my amateur sleuthing came up empty handed.
Thanks again!
Previous swepties:
Previous swepties:
- Grodr625
- City: Seattle
Even then VIN decoder here conveniently leaves out the S400! The shop manual has not been as useful as I had wished. But she runs and drives now and is stopping on three drums with my leaky cylinder plugged at the tee on the rear axle. This has renewed steam going into the project considerably :)coelcanth wrote:i can see you have a tough project ahead of you ..
Previous swepties:
Previous swepties:
For the most part, the S400 is identical to a D400. Basically, its a D400 with a school bus body on it.
Take the number given in the drawings and go to the page with that number before the part description. Then go down the 1st column until you find "D" or "S" and the column marked 400 will have a 1 or 2 (amount) or more if needed. The last column on this line is the part number.Grodr625 wrote:soopernaut wrote:Did you look through any of this?
Thanks again!
- Grodr625
- City: Seattle
So I finally got the rear drums off and luckily there's plenty of meat left and they are being cut by a heavy truck shop in town. My next puzzle is finding the correct wheel cylinders. The casting #s on the ones installed are a little difficult to make out. They read "BENDIX 9743" I THINK! This 9743 crosses over to a wheel cylinder that does not match what I have.
Per the Dodge parts listing it should require part # 2084-408 which does indeed look like what I have mounted, problem is the thread pitch is off. 7/16-24 from my brake line to 3/8-24 into these Napa wheel cylinders https://www.napaonline.com/en/p/UBP27342
The parts listing also shows #2084-406 for the front brakes which crosses to a rear wheel cylinder with thread inlet size of 7/16-20, closer! Will 7/16-20 and 7/16-24 play well enough to thread without damage or leaks? **Its possible the 1/4" tube line that I replaced, but haven't run pressure through, was the wrong thread pitch! ** Yikes
https://www.napaonline.com/en/p/UBP28850
Am I decoding my casting # incorrectly? The above links are what it should look like, but the advertised fitting size is wrong. Should I keep digging for the right stuff or consider running adapters to each port?
https://i.imgur.com/a2EHS8t.jpg
https://i.imgur.com/3qvqI9K.jpg
https://i.imgur.com/Y0SeQmb.jpg
Previous swepties:
Previous swepties:
- moparbay
- City: Rapid City
- State: SD
I know this will not help much but on my 67 D400, the front and rear wheel cylinders are absolutely different. The front only has 1 wheel cylinder per side (assuming it is a double piston)and the rear has 2 wheel cylinders per side (assuming single piston). I am in the process pulling the rear hubs off mine to see what they are.
moparbay
Ole "Blue" 68 D100 Adventurer
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
Personally I would source the correct line fittings to fit wheel cylinders to make up lines from bulk line. When I redid the brake system in my 70 D500 every line was hand fabricated and bend by me for a nice fit. Only thing bought pre made were the hoses.
did you ask seattle brake and clutch if they shows WC part numbers?
