Repro gas tanks
- Jims68
- City: Edgewater Park
- State: NJ
Repro gas tanks
Saw this on Facebook. Says 61-71 but I 'thought' that the 61-68 was different than the 69-71 tanks... Anyway here is a link:
https://vansauto.com/product/61-71-dodg ... chttnk611/
Re: Repro gas tanks
Question to Vans Auto regarding the 61 to 69 and 70/71 should be asked
Re: Repro gas tanks
Made in Taiwan. Its 61-69 version, probably the 18 gal size. Nothing like the 70-71 tank.
Re: Repro gas tanks
Terry, your eyes are good for an old fart.PwrWgnDrvr wrote: ↑Thu Jun 09, 2022 10:49 pmMade in Taiwan. Its 61-69 version, probably the 18 gal size. Nothing like the 70-71 tank.
- Jims68
- State: NJ
Re: Repro gas tanks
I haven't seen a 70-71 tank for a long time and forgot what they look like. I WISH I had saved one from one of my parts trucks when I had them, just because. I also thought the '69 tank was part of the "different" tanks.PwrWgnDrvr wrote: ↑Thu Jun 09, 2022 10:49 pmMade in Taiwan. Its 61-69 version, probably the 18 gal size. Nothing like the 70-71 tank.
- martincom
- City: Five Points
Re: Repro gas tanks
'70 & '71 Fuel Tanks
They actually manufactured two different, in cab, tanks for 70 & 71. The trucks built for the CA market had a 23 gallon with a vapor recovery system. The rest of the country had 25 gallon tanks w/o vapor recovery. Outside dimension were the same. The vapor recovery tanks sending unit was on the right side of the tank, not the center, like the pre-70 tanks. I don't know where the sending unit was in 70/71 non-vapor recovery tanks, as I've never seen one. The reason the sending unit was on the right and the vapor recovery tanks had a smaller capacity was because there is an internal, center mounted, 2 gallon expansion tank. It has small holes between it and the main tank so the fuel can expand as it warms, but not large enough to allow it to be filled when fueling (unless you're going to trickle the fuel in). The vapor recovery tank has two 1/4" hose barbs at each end of the tank. The one on the left is the vent and the right is for the vapor separator drain inlet. The vapor recovery tanks had a vapor separator mounted in the upper right rear cab pillar, as evident by two mounting screws that are visible from the cab interior. The vent line, from the vapor separator runs to the crankcase breather where it is connected along side the hose from the air cleaner. The fumes are drawn through the PCV system to be burned with combustion air.
Pre-1970 tanks had 18 gallon capacity and were not as tall as the '70/71 tanks. The interior cab finish panel, below the window, is shorter in '70/71 cabs than earlier cabs. So this Van's replacement will not be a "bolt-in" replacement in '70/71 cabs.
- martincom
- City: Five Points
Re: Repro gas tanks
1969 Tanks
From Mark DuVerger, the filler neck changed mid-year in 1969. I'm going to speculate that is when they changed from the "hose barb" fill neck fitting on the tank, as pictured on the Van's replacement, to the rubber grommet tank with a slide-in filler neck. The '70/71 tanks also had the slide-in filler neck. I'm wonder if they changed to the larger fuel tank along with the slide-in filler neck, mid year 1969?
- City: Niagara, ON
Re: Repro gas tanks
For those interested I was given the dimensions 57 x 17 x 6 inches from Vans Auto which appears correct for my '67.
How is the sending unit removed/inserted and secured? I'm use to seeing six small bolt/screw holes for installing the sending unit. Is it a push and rotate fit?
- martincom
- City: Five Points
Re: Repro gas tanks
It appears to be the lock ring, as utilized in later models and the repop sending unit.
Re: Repro gas tanks
Sender is retained in ALL sweptline tanks by a lock ring, (and gasket under the sender).
Re: Repro gas tanks
There was also a 16 gal version prior to 70/71. Not only are 70/71 taller, they are also longer. That is why the jack was moved from behind the seat, at the right end of the tank, to under the hood.martincom wrote: ↑Fri Jun 10, 2022 7:23 am'70 & '71 Fuel Tanks
- City: Niagara, ON
Re: Repro gas tanks
- Jims68
- State: NJ
Re: Repro gas tanks
I just use a hammer and a brass PUNCH to "un-screw" the ring. Brass won't cause any sparks to worry about. It just spins counter clockwise (like a bolt) to remove. When installing the ring, it just screws on (turns on) the same way as a bolt. It will have a "stop" on it so you can't twist it on too far.67step100 wrote: ↑Fri Jun 10, 2022 12:41 pmDo you need a special tool for the lock ring to get the sending unit out? Having never seen one of these before I don't know how it works. Thanks.
- City: Niagara, ON
Re: Repro gas tanks
[/quote]
[/quote]
Thanks Jim.
[/quote]
Thanks Jim.
- City: Niagara, ON
Re: Repro gas tanks
Thanks Jim.Jims68 wrote: ↑Fri Jun 10, 2022 2:40 pmI just use a hammer and a brass PUNCH to "un-screw" the ring. Brass won't cause any sparks to worry about. It just spins counter clockwise (like a bolt) to remove. When installing the ring, it just screws on (turns on) the same way as a bolt. It will have a "stop" on it so you can't twist it on too far.
