Speedometer after changing rear diffs.
- City: Calgary
Anyone know how to re sync speedometer? Changed rear diffs from 391’ to 294’s.Think my Speedo is about 10-15 miles to slow.1967 Dodge D100. Got a feeling this might be a pain in the arse,lol.
- City: Binghamton
- State: NY
Re: Speedometer after changing rear diffs.
With my 65 I went from 4:88 gears to 4:10 I was off by about the same. I used a gear reduction box from an old Chevrolet. It screwed between the transfer case and to speedometer cable. It is accurate now.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- City: Binghamton
- State: NY
If your truck is an automatic it’s a mater of changing speedometer gears. They are easy to change but can be hard to find the gears.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
You can also easily change gears on a std tranny. Step by step instructions are in the FSM.
- martincom
- City: Five Points
There are charts in the service manual that indicate the number of teeth the speedometer pinion should have fro a given rear axle ratio and tire size combination. There also charts and calculators online that will yield the same results. Speedometer pinions are available from places like Year One and Ebay.
- City: Calgary
Thanks for the info.It’s a 4-speed,maybe that makes it easier.
- City: Calgary
Hello PwrWgnDriver. This may seem like a stupid question,but what is the FSM?
Factory Service Manual
Reprints available from Bishko, better quality than new!
- City: Calgary
Thanks,I'll check it out.
- martincom
- City: Five Points
Manual or automatic, the speedometer pinion is the same.
Tip: Only lift truck from the rear when changing. In this manner, all the fluid/lubricant will flow to front of the transmission and you won't need to drain anything (or get a bath) when you remove the pinion.
