Radiator
- City: Binghamton
- State: NY
Radiator
What are the differences between a big block radiator and a small block? Is there more surface area or more cores? Or is there a difference at all? I’m hoping to use the small block rad with a 440. It’s not crazy HP. Just a bone stock motor home engine from 1977.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Re: Radiator
One difference is the hose connection locations.
Re: Radiator
There's a good deal more cooling capacity for the BB radiator.BigBlockTrucks wrote: ↑Thu Feb 04, 2021 2:12 pmWhat are the differences between a big block radiator and a small block? Is there more surface area or more cores? Or is there a difference at all? I’m hoping to use the small block rad with a 440. It’s not crazy HP. Just a bone stock motor home engine from 1977.
I'm not certain how many cores deep they are.... but the overall
dimensions are bigger. I think you'll be woefully disappointed if
you try to use a SB radiator for more than the fact the inlet/outlet
locations are different.
- City: Binghamton
- State: NY
Re: Radiator
What are some options for a sufficient rad? Is a bolt in replacement available? Is there an aluminum alternative that fits with some mods? I’m not concerned about in and out. Top hose is center on engine and I have WP housings for either side.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Re: Radiator
I'd put an ad in the Parts Wanted section to see if anyone has a stock rad
you can have re-cored. I'm sure there are aluminum alternatives too... its
just a matter of investigating suppliers....
- my5thmopar
- City: Columbia
Re: Radiator
My 64 D100/440 has a Champion with minor modification. I had it in my 70 D200 with a 383. I went back to a stocker on the 70 and I like it better. Craig
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
- City: Binghamton
- State: NY
Re: Radiator
Champion makes quality stuff. I have one in my 60 cooling a 383. You said with modification ,what was the rad originally made for?
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- City: Binghamton
- State: NY
Re: Radiator
There is more space in the 65. If spending for the aluminum rad it would look and work better if it took up all of the space available.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
