Automatic transmission
- City: Binghamton
- State: NY
Many time swept owner first time on the board. After owning and parting out a dozen or so, I have yet to see an auto in a w series. Did dodge ever make a power wagon without a clutch pedal?
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Re: Automatic transmission
Welcome to the site.
I've yet to see any W100 or W200 earlier than '69 with an automatic.
The '69-'71 W100/200s came with them.
In 1969 the transfer case was moved towards rear end from transmission making room for an automatic with a short tail shaft and driveshaft to connect to T Case.. I looked at putting an automatic into my 66 W100 many years ago and felt it was gong to be a bit too much work.
- City: Binghamton
- State: NY
Mine is a late 65 w 200, and I am debating on auto or 4 speed to go behind a 440. I have the auto with park brake from the motor home where the engine came from. I don’t think there is enough room to put that 727 between the engine and transfer.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
I'm sure you know that if you are planning to do a 440 / auto as a 4 X 4 you'll be cutting the main crossmember, which with a manual takes up the bulk of the torque from the motor. So without it, you'll be putting a LOT of twist into the frame from the front mounts alone, with less reaction stiffness in the frame and with all that torque going into the t-case. I've seen a 2bbl 383 crunch the mounting isolators on an NP201. Nor is the support for that t-case terribly beefy (the 'bridge' across the top can crack at the apex). So what's your plan to manage all that crank with so little torsional stiffness? Sure hope you plan to strap those front engine mounts. I've torn those out with annoying frequency with only a 318!BigBlockTrucks wrote: ↑Tue Jan 05, 2021 11:22 pmMine is a late 65 w 200, and I am debating on auto or 4 speed to go behind a 440. I have the auto with park brake from the motor home where the engine came from. I don’t think there is enough room to put that 727 between the engine and transfer.
Edit: So I went and did a little sleuthing. Poly-Loc mounts are SPENDY, but they murder a potentially catastrophic problem: https://p-s-t.com/i-23160496-polyloc-motor-mounts.html It would take some fab work to make the car mounts fit though.
You might need to research a short tail shaft, sans parking brake, and determineBigBlockTrucks wrote: ↑Tue Jan 05, 2021 11:22 pmMine is a late 65 w 200, and I am debating on auto or 4 speed to go behind a 440. I have the auto with park brake from the motor home where the engine came from. I don’t think there is enough room to put that 727 between the engine and transfer.
if you'd have enough room to stuff it between the 440 and t-case. Does your '65 W200
have its own parking brake on the t-case already?.... Your current bell housing cross
member would have to be removed, leaving the "stubs" for the leaf spring perches
and the holes that are provided to install a spanner to tie the stubs together under
the 727. There's more to do to accomplish the task.... but first things first....
- City: Binghamton
- State: NY
Not that I’m looking to put an auto in my truck more that I’m looking at the options. The bb bell and flyweel aren’t cheap. Thought It may be easier to go auto and sell the 4 speed stuff. And so it turns out, I was wrong. 4 speed is the way to go
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- City: Binghamton
- State: NY
I know everyone here loves to see pics (me included). My brain isn’t computer friendly so it may take a bit to post pics.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- City: Binghamton
- State: NY
Until then... it’s a late 65 former brush truck from local FD LU-2 front mount winch and almost no other options.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Is it a local truck? Just curious.BigBlockTrucks wrote: ↑Wed Jan 06, 2021 7:23 pmUntil then... it’s a late 65 former brush truck from local FD LU-2 front mount winch and almost no other options.
I see you live in the hometown
of McIntosh Audio Equipment.
- City: Binghamton
- State: NY
Former brush truck from endwell ny just down the road from me.Hobcobble wrote: ↑Wed Jan 06, 2021 7:32 pmIs it a local truck? Just curious.BigBlockTrucks wrote: ↑Wed Jan 06, 2021 7:23 pmUntil then... it’s a late 65 former brush truck from local FD LU-2 front mount winch and almost no other options.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
The mechanical BB bell is even more costly than they hydro BB bell.
Just from the town's name it came from..... you have good karmaBigBlockTrucks wrote: ↑Wed Jan 06, 2021 7:56 pmFormer brush truck from endwell ny just down the road from me.
going for you.
- City: Binghamton
- State: NY
I’m going with the hydro bell. I have most of the pieces and it’s much easier than the automatic idea. Thanks for all the info everyone!PwrWgnDrvr wrote: ↑Wed Jan 06, 2021 8:52 pmThe mechanical BB bell is even more costly than they hydro BB bell.
I will post more as I make progress.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
