Through the process of trying to get Isaacs truck back together, I ran into a small issue. I did search for this first, but didnt really get many results. There was a part number posted, but it might not be good. I also did a google search, and it brings up A and B body parts.
I need the right clutch fork return spring. The spring I have is not the right one. I did find the bracket, but I guess the PO had broke the spring and remounted the bracket elsewhere and just used another spring. In the build thread PwrWgn posted a picture of his truck, and the spring passes between the slave cylinder and the bellhousing, which means it needs a long end. I could try and make something work, but it might put the clutch fork at a weird angle, and cause problems.
Is there a source you all have used to find this spring? Is there a crossover, like one of the A or B body dodges from the late 60s? Is there a junkyard I can call and get one sent out?
Clutch fork return spring
- City: gray
Isaacs truck:
Re: Clutch fork return spring
The spring u posted looks like a throttle return spring. I have seen springs like that stretched a bit and flattened (not uncoiled) to squeeze thru that space between the slave and bell. That worked w/o issue.
powerwagon54 might have one available.
Maybe someone here with one could post a picture up with some measurements. That'd give you a good starting point.
