Mine was converted sometime in the late 1990's by a previous owner. I have not had luck figuring out my what steering box I have. I sent pictures to Redhead Steering boxes, a rebuilder, I called Borgeson to inquire about a box that is part of one of their conversions that looks a lot like it, the guy I got wasn't willing to help. I've searched pretty thoroughly and scrolled through pages of pictures, no luck in getting a solid answer as to what box this is. Really hoping someone here knows something.
This is the box I have. It spews fluid from the output shaft, running or not.
Another Power steering thread.
- City: Lake Chelan
- City: Lake Chelan
Re: Another Power steering thread.
Here is the bracket they made to mount it. It works, I am going to improve on it if I use this same box again, they used spacers they could have avoided using with different bolts.
- City: Lake Chelan
Here's my truck in my shop.
- City: Lake Chelan
Here's the other half of the project. The column doesn't line up with the shaft, and the joint rubbed on badly cut way body metal.
This is after I cut away all the sharp metal and ground off the bed liner, caulking, and spray foam.
No images
- City: Lake Chelan
Crap! I'll have to fix that after dinner.
- DicksDodge
- City: San Dimas/CA
Seems like you didn't figure out the pics. Would love to see them. PM me if you can, or drop me a note and I'll send you my email. Getting ready to do the final work on my 70 and PS is a must.
1970 W200 Camper Special 383/4sp.
2018 Ram 2500 Crew Cab LB Cummins
- City: Binghamton
- State: NY
I am curios also of the conversion, what was available then? I Also got no pics.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
